跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
Intermitten LED #2 on Logic Board
I have a good working power supply. It has been tested as well as the logic board.
When I plug the AC plug into the electric outlet without turning on the system the #1 LED lights which it what it should do.
The fans keep starting and stoping and the #2 LED blinks off and on. Is this normal? When I press the start button it continue to do the same. Could there be an open circuit?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Carefully disconnect the power switch connection on the logic board. Does the #2 LED stay off and the fans are not running?
You may want to run the diagnostics. With everything connected reboot the system and hold the D key did any errors pop?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
duane c johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 40
