跳转到主内容
苹果AirPods是于2016年12月发布的无线耳机。
96 个问题 查看全部
Where to buy replacement battery and logic board
Does anyone know where to buy a replacement board or battery for the charging case?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
apple replace battery for $49. I would probably take apple up on that as the repair/replacement of the battery is not for the faint hearted. If these are less than a year old they are covered by the warranty.
这个答案有帮助吗?
得分 2
7条评论:
I have already disassembled the case, and just need the parts to replace them with. More useful would be the logic board, as the device can function with a bad battery for longer than it can with a dead board
完成的
So no one knows where to get a new board?
完成的
Aaron is pretty right, it seems you can buy people's left or right second hand airpod, but finding the components is a probably not going to happen. The airpod is cheaper to buy than it would be a logic board because the repair is a nightmare of glue/sharp knives/heat and tiny, tiny bits that not many people are going to want to do...good luck in your quest.
完成的
How does apple replace the battery then if they are so horribly designed?
完成的
@albert8181 They simply don't. They just give you a new charging case and call it good. That is what I have heard anyways.
完成的
显示更多的2条评论
添加一条评论
@albert8181 No one supplies these boards because no one wants to or even can repair and replace anything inside these charging cases due to their terrible repairability. I scowered the internet and I couldn’t locate a Logic Board or battery anywhere. Just get a new charging case if you even want to use these AirPods you have.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 362
