跳转到主内容
The RCA Voyager Pro tablet is a perfect entry into a world of wonder and entertainment. Running on Android’s Lollipop, the Voyager Pro is sure to excite and entertain.
47 个问题 查看全部
Where I can fix Voyager screen problem
Need someone to repair or replace Or fix Voyager screen in Sardinia Italy.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The best guy in your part of the world would be
arbaman
@arbaman
Want to contact me ? contact@giorgio.e4ward.com
这个答案有帮助吗?
得分 2
3条评论:
@mayer Thanks for thinking about me, I appreciated, the posting didn't catch my attention being more or less an Apple only technician.
Let's see if the OP gets in touch. However, unless it's strictly for data recovery purposes, given the present prevailing prices for a new device, I'd not recommend fixing it from a purely economical prospective. @ajcooke01 for reference.
完成的
@arbaman @ajcooke01 can you help?
完成的
@rajen As already mentioned before, if you have precious data to recover from your tablet, it might be worth trying to fix it and you can contact me directly. Otherwise, the cost of repair will probably be higher than the cost of a new one..it's really up to you.
完成的
添加一条评论
If you can find a place where you would be able to buy the parts (digitizer and screen) and have the repair shop install the parts for you then you might find more places offering to fix the tablet.
If your screen is cracked/malfunctioning but the LCD is fine, buy only this part
If your screen is cracked/malfunctioning AND the LCD is broken/malfunctioing, buy the part above and this part here too.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rajendra Velip 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 91
