跳转到主内容
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
90 个问题 查看全部
Why no power on my n64?
I was sitting and playing on the n64 and then i tilted it up a little and the light went out.
and there is no power! Also i was testing the another clean system but i accidentally put the memory controller accessory into then ram pac port and now it wont show a picture!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个回答
已选择的解决方案
I found out there is a rip somewhere in the cable. a fix for now is leaning against something where it connects!
这个答案有帮助吗?
得分 0
添加一条评论
I took the thing apart and when i turned it on it worked so i put it together and then when i turned it on again it was doing the same thing again.
repeated the steps and instead of the end result a confused look on my face and no light it came on o well!
这个答案有帮助吗?
得分 0
添加一条评论
try a new cable or possibly search on youtube
这个答案有帮助吗?
得分 0
评论:
I think it was the supply was weak. needed to let it power cycle
完成的
添加一条评论
添加你的答案
Bobby gunnels 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 105
