跳转到主内容
2006 iMac 2Ghz 512mb Core Duo will not boot.
I have recently acquired the above machine to help my grandson with his schoolwork due to not being able to afford a laptop for him. The machine powers up OK but it keeps giving me a screen telling me I need to restart. The lines of data I can see in the background state 'Mac OS version - Not yet set so I am thinking there is no OS on it.
Will this need to go to the repair shop or skip or is there anything I can try to fix it? Any advice would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Here's the details to your system: 20" iMac G5 2.1 GHz system specs
完成的
添加一条评论
1个答案
已选择的解决方案
Did your system come with the Grey CD/DVD disks? Or, did it come with a Retail version of Mac OS-X Leopard 10.5.8"? Which is the highest OS this system will run. You’ll need to find the disks to re-install the OS as it does sound like the OS installed is corrupted.
As to using this system as long as its not used on the internet then you’ll be safe. If you are thinking of using it on the internet you’ll encounter both issue with the Web browser as this is such an old system no one is making a modern version which supports HTML 5. Even if you are just using it for email it would be risky as there are a lot of security breaches in this OS level. Lastly you won’t be able to run any Intel based applications only PowerPC versions which have long since left the market place.
So the bottom line: This is not a very good system for your grandson - Sorry ;-{
I would recommend getting a ChromeBook laptop or tablet as a better investment Should I Buy a Chromebook? Buying Guide and Advice. Or look at getting a newer used Apple system. If you can find a MacBook or MacBook Pro 2007 or newer that would be better or a iMac 2009 or newer.
Looking through the links I’ve posted here you can find the system you have found used to check out the OS support (look at the bottom of the given entry) You really don’t want a system that it only supports Mavericks MacOS 10.9 as the highest supported OS.
这个答案有帮助吗?
得分 2
评论:
Guessed as much but particularly as it had no discs. Thanks very much for the speedy reply - I will look at the links you posted.
完成的
添加一条评论
添加你的答案
Steve 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 50
