My Xbox 360 Wi-Fi Has problems troubleshooted already
Connects to wifi okay but then dosen’t do anything with it. Like it says connected but nothung that requires wifi works. Same problem with Ethernet. Please help
Hmm. Try manual wifi settings, look into it, and make sure everything seems right. Other than that, best I could tell you is to replace the motherboard for it as it doesn’t work with Ethernet either OR just fresh install the system.
这个答案有帮助吗?
How do I fresh install the system?
Erase Xbox 360 Data
Under Device Options select Format and verify you want to remove all content.
After that, you'll be asked to restart the console.
That's it! ...
After that you will need to sign in or set up your Xbox Live account and configure everything how you want it.
This will delete all your games but may fix your internet problem.
I just added a picture of it the memory has issues as well
I'm kind of confused pal.
The picture shows your internet connection is completely fine. You just need to pay for Xbox Live.
Am I missing something?
Hello,
You need to check you internet connection & talk you internet provider.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 198
