Why does my switch pro controller's A button sound worse?
My A button on my switch pro controller doesn't have the same clicking sound as the rest, like I'd press B Y and X and it would have a clicking sound, but when I press the A button it's just silent. It still works and everything I just don't know why it is silent while the others make a clicking noise
If you can take the button off, you can check the inside to see if there a problem on the inside. From there, you can probably fix it.
由 Pathfindergeek 完成的
I have a similar problem, but instead the "A" button still clicks when pressed on the center. It's just like that when pressed more towards the bottom. Please reply if you happen to find a fix. Thanks.
由 ZensGamez 完成的
