High ms only on this PC
Hello guys.
I just build a new PC for a friend and I’ve noticed a problem. When I play offline games everything is Perfect, but when I play an online game ms are getting crazy. I thought at first that the problem was with the internet connection but later I tried with another pc to play the same game and I had 21ms instead of 300ms I had with the new PC. What can be the problem with the new PC and gets so high ms?
PC Specs :
- Motherboard : Asrock B450M-Pro4
- CPU : AMD Ryzen 5 2600 Box
- PSU : Corsair VS Series VS650 White
- RAM : G.Skill TridentZ RGB 16GB DDR4 - 3200MHz (F4-3200C16D-16GTZR)
- GPU : Gigabyte GeForce GTX1060 6GB (GV-N1060WF2OC-6GD)
- CASE : NZXT H500
- SSD : Samsung 970 Evo NVMe M.2 250GB
- HDD : Seagate Barracuda 2TB
- Cooling : CoolerMaster MasterAir MA410P
Ethernet? Or wifi? I am going to guess Ethernet as the B450M does not come with wifi. I have the mono, nice motherboard. The higher ms can be nothing else but connection speeds(Not necessarily your internet but how its being delivered to your pc), you need to test more variables. Maybe a different ethernet cable, plug it in a different port. Go to your router settings, disable wifi for a moment and see how fast that PC works then, as you will be connected through an ethernet cable.
My PC connection speeds are pretty good but at times it hits what you are receiving even when I am the only one on the internet. So I turn off my wifi in the router settings, and it fixes it instantly. Other devices even if you don't think it is doing so may be taking up the internet.
由 Brett Johnson 完成的
The problem is that in the same network , with the same router , with the same cable other computer works perfectly.
由 Savvas Giannoukas 完成的
What is the Ethernet board or are you using the on-board port? Are they the same between the systems and what are the settings are they the same?
由 Dan 完成的
Hmm. Test your internet connection on speedtest.net, on both systems. It will test your ms, download, and upload. Tell me the results between the two. Are you sure it couldn't of been some fluke?
由 Brett Johnson 完成的
