Device won't power on
Device would not power on.. I replaced battery, charging port & screen. It still will not power on.
Do you have any insight as why the phone died; drop, previous repair attempt…water? That would give us a clue as to where you start.
Try booting just the board, known-good battery and Lightning port. Then connect it to an iTunes enabled computer. If it is recognized, then some peripheral is causing issues. If it isn’t, then you likely have a logic board issue. You could start probing the board by looking at the main voltage rails (PP_BATT_VCC, PP_VCC_MAIN and PP5V0_USB). If you’re not comfortable with that, have it looked at by a micro-solderer.
这个答案有帮助吗?
how to just boot the board
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
1条评论
All I know is its 4 years old and it was thrown across the room by kids.
由 chrisellis87 完成的
