跳转到主内容
No lights on drone when it's powered up
I have a promark gp s shadow drone until lately it's been great but went to fly it tonight and powered it up as normal and I have no lights at all even went through set up and nothing it won't sync w remote and won't fly I have tried to reset it and trouble shoot the problem to no avail anyone w any ideas would be great thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Scott it could be the battery is not getting a good charge? Use a USB charger that is minimum 2.0amps. Is the battery bubbling up? If yes then the battery is bad. When inserted into the drone does the battery LED lights up when you press the on button? If yes then there maybe a connection issue with the contacts. If you have a volt meter check the battery terminals for voltage while pressing the power button. If voltage is present then internal wiring and or the main board is failed. You can Google the part online.
这个答案有帮助吗?
得分 0
3条评论:
Scott if you haven't solved your PROMARK SHADOW drone lights problem try to disconnect both camera cables power up the drone and see if you can bind the transmitter. If yes then reconnect the camera and do the factory gyro reset procedure by simultaneously moving the left stick up 10 o'clock and the right stick up 2 o'clock position hold until you see the lights on the drone flash then go steady.
完成的
Scott you had originally stated that you reset the drone? You cannot do a factory gyro reset until you first bind the remote to the drone. Does the blue l.e.d. lights on the battery all light when you power up the drone? If no then the lithium ion battery is expired or your charger source is to weak to fully charge the battery. You should be charging the battery with at least a 5 volt 2.0amp hour capacity USB wall charger anything less won't provide a full charge. If you have crashed your drone there could be internal damage to the main board and that could be why it's not powering up.
完成的
Same problem...so frustrating! We do have blue lights come on immediately when turning on the drone and stay on until we turn it off. We have tried many different ways without success ? Ddoes anyone know if you have to have a Sim card in for EVERYTHING to correctly function?.that's the only thing different, I'm going to put a new one in to see but seems silly it would affect everything. Can anyone at all please let us know what is going on??? Ours worked one day then the next day the lights don't come on(besides blue battery lights) and it won't do anything. We losves our drone so much! Please help if you know of anything! Thank you for your time! ~Candice
完成的
添加一条评论
添加你的答案
Scott lynch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 830
