跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Why can't I hear other callers but they can hear me fine?
When in a call can’t hear other person. Can hear on loudspeaker, headset, Bluetooth. Earpiece speaker works fine tested it. Tried another front camera flex no luck. Tried apply pressing near front camera no luck. It’s Not stuck in headset mode. Done resets, Updates, Bluetooth on/off, Aeroplane mode on/off still no luck!!…Anyone having same issue on the 6S Plus or anyone have a FIX?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If the ear speaker works fine during your tests, then it’s not a hardware failure. Try hard resetting your phone (Home & Power Button for 10 secs) or if that doesn’t work, the go to Settings/General/Reset/Reset All Settings.
这个答案有帮助吗?
得分 2
1条评论:
Isn’t the earpiece speaker line different from the loud speaker line for audio input? Correct me if I’m wrong but I’m fairly certain he could also have a bad circuit on the earpiece line as the loudspeaker work on separate circuits
完成的
添加一条评论
Did you try to replace earpiece speaker, i had that same issue not on exact iphone. it was iphone 7 i just replaced the earpiece speaker.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shok 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 76
