跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Adhesive Replacment After Repair
After opening and repairing an iPhone is it required to replace the adhesive that was broken while opening. This may sound like a dumb question, but I just want to double check.
Thank You,
Alexander Wiand
xtwiand@gmail.com
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It’s up to you. If you care about quality or water resistance, do it.
I have attempted and successfully resealed my iPhone X, the experience should be comparable to iPhone 7, with ways to test seal quality included as well.
1: If you replaced the screen, don’t bother with water resistance anyway. You cannot be sure that the replacement screen has the screen bezel correctly bonded to the glass so it is sealed properly. The same cannot be said either for top speaker mesh if you touched that part. If you have replaced the internal components like battery or rear camera, you can have a try.
2: Use IPA wipe to wipe the contact surface of the casing and the display, make sure it is ABSOLUTELY clean. Inspect for physical deformation if the phone has been dropped. Deformation will result in a bad seal.
3: Clean the adhesive pack so that there are minimal dust or adhesive residue around the edge. Residue will collect on the side of the casing, then when the screen is closed, get scraped down onto the adhesion surface, bad seal again.
4: Apply the adhesive as shown in the iFixit tutorial video, don’t peel any of the front liner off yet.
5: Extra step. Use IPA wipe to wipe AGAIN to away excessive goo off of the inner side of the casing, so they don’t get scraped down with the display. Don’t use too much IPA, too much IPA will seep down towards the adhesive and potentially dissolve it. This step is actually needed because the repair environment and adhesive quality is not as good as the original factory or authorized service center.
6: Reassemble the phone, double check for dust along the edges, peel off the final liners just before you close up.
7: Use some heavy object to press down the phone to activate the adhesive. Use a little bit of heat if you are concerned about seal quality.
8: Vacuum test. Download any barometer app from the App Store, it will show the internal absolute air pressure. To test for a good seal, first squeeze the phone real hard and hold it, wait for air to go out through the vent then block the lower baro vent so air doesn’t come in or out, then release the squeeze. If there is a pressure drop and it doesn’t leak back, you have at least completely sealed up the phone. The test doesn’t work for iPhone Xs, Xs Max due to barometric sensor is no longer inside the case.
If there are any dust trapped inside the contact area, the phone may still be sealed but with compromised pressure rating. The adhesive strip is very narrow and the effective adhesion area can be even narrower if there is something trapped in between. Water pressure can tear it through so if you are not sure it’s absolutely clean before closing up, consider the phone as splashproof only even if the vacuum test passes.
这个答案有帮助吗?
得分 3
2条评论:
Interesting!
完成的
Thank you very much. This answered my question perfectly.
完成的
添加一条评论
I guess that depends…
If it’s for you, then you can do whatever you please ;>). If you’re doing this for someone else, especially if you are charging them, then absolutely you should. It’s just a question of best practices and attention to detail.
If you think that doing this will make you’re phone water resistant again, I would disagree however. It’s hard to put it on perfectly and even if you did, you are not doing it in under factory and clean room conditions. That doesn’t mean it won’t help keep water out but you should never expect it to be as good as factory fresh and even factory fresh iPhones let in water occasionally.
这个答案有帮助吗?
得分 2
1条评论:
I've managed to find a better way to apply adhesive and test for seal quality without professional equipment, all you need is any app that can read baro sensor data.
完成的
添加一条评论
添加你的答案
Alexander Wiand 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 411
