跳转到主内容
修复你的物品
维修的权力
商店
联想 Chromebook 维修指南。
60 个问题 查看全部
Any ideas on how to remove small silica gel balls from headphone jack
So everyone recently got new chromebooks and protective pouches, but the pouches had silica gel packs which many didnt remove, so many are breaking open, and then the little beads inside are getting stuck in peoples headphone port.
I know iFixit sells the extractor tool, but I dont know if it would work in this case as its not a headphone jack, but a small round bead.
If anyone has any ideas on what to try, or if the tool would work, that would be great.
Also, one was taken apart, but there is no easy way to remove it from the inside.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
1个回答
最有帮助的答案
This isn’t the greatest solution but you could take a very small drill bit and drill into the silica bead until it breaks into more manageable pieces that you can remove with tweezers. Drill very slowly and cautiously as we do not want to break the headphone jack with excessive force! I did this with a small pebble that got stuck inside my iPad’s headphone jack and it went according to plans.
Update (10/11/2018)
You could try just using these tweezers to grab the silica pellets, they are very thin and might be able to slip under the pellet and pull it out.
Tweezers图片
产品
这个答案有帮助吗?
得分 1
评论:
Thanks. I thought about doing that or using a pin to stab it. But I was looking more for a more easy and repeatable method as it's happened a few times already and I want other people to be able to do it. But that's something for me to keep in mind
完成的
@cam2363 Yeah, it is kind of a last resort type of solution but it has worked for me. Unfortunate!
完成的
Ill give the tweezers a shot too. I have a few extra pairs, so if they work all the better.
完成的
添加一条评论
添加你的答案
Cameron 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 19
总计 1,133
