跳转到主内容
家用物品维修 DIY 指南,从家具到下水管道解决应有尽有。
3883 个问题 查看全部
Anyone familiar with Saeco super auto espresso machines?
I have a Saeco Caffe Charisma home espresso machine that has a problem. The red light (27) comes on to indicate that the tank is low on water even though the tank is full. Anyone have any suggestions on how to fix this? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
these low level sensors are usually triggered by a magnet in the tank. Try to figure out if it's a magnet or float that raises in the tank. I'd just get a magnet, remove the tank and run the magnet around the tank housing to see if the light goes off. I bet you'll find that there is an obvious spot on the tank for the magnetic float and that it's either stuck down or missing.
这个答案有帮助吗?
得分 1
添加一条评论
There is a floating magnet inside the water tank. Sometime becomes waterlogged. Can be replaced easily or you can take the cover off and disable by splicing the wires together on magnetic switch then you have to be careful about keeping water level up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matthew Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,462
