跳转到主内容
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
50 个问题 查看全部
My engine shuts off sometimes when I’m slowing down.
I have a 2010 Ford Escape XLT. In the next couple of days after I put gas in my tank, my engine will shut off as I’m slowing down. As I apply the breaks (sometimes not always) my battery light will turn on followed by the oil light, then the engine will shut off entirely. When I turn the car off then on again it will start up like normal. My mechanic has had my car for days and can’t get it to shut down as I experience it to. The alternator is brand new so thats not an issue, I’m frustrated because we can’t quite figure out what is wrong. Has anybody else experienced this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Sometimes this can be the result of a bad battery. As your car is moving the alternator can keep it running, but braking actually uses a lot of power as well as slows your alternator down. I would take it into an auto parts store and have them test the battery.
这个答案有帮助吗?
得分 1
添加一条评论
it’s your battery that needs to be reset. No lie you must turn the key ignition onand off over and over again while car is off. Then move the shift gears and pump the brakes as well. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jayme K 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 34
总计 1,907
