跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
Replaced flex cable, now power, home, touch screens not working.
I have two ipod touch gen2 (one 16gb, one 32gb). Replaced flex cable for different reasons on both, but after installation, both exhibit identical symptoms: No response to touch screen, home, or power buttons. I don't know if volume or wifi work or not, but the battery charges and both will sync with itunes. I followed instructions for flex cable install using 3M 9703 tape, per Mr. Gilks on youtube. Any suggestions on where I went wrong or what I can try next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Stacie, I am sorry I do not know Mr. Gilks. What I suggest is that you take a close look at this guide iPod Touch 2nd Generation Logic Board Replacement and double check your work. Make sure that all your connections are clean and that all connectors are seated right. Also, why did you need to replace the flex cable?
这个答案有帮助吗?
得分 1
1条评论:
These units had been opened by previous owners. One had a torn cable, the other had an unresponsive touch screen and I'd replaced everything but the logic board and flex cable, so I figured that was the next step. Thanks for the link, I will give it another go!
完成的
添加一条评论
try VERY light heatgunning on flex cable so it will have a better connection to logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stacie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,946
