跳转到主内容
Released in August 2015, Model number: P01M, Intel Atom Processor Z3530
21 个问题 查看全部
Why the tablet would only charge when it is on?
My Asus Zenpad  would only be charged when it is on. I have used the factory cable and charger (adapter) and also used others. the result is the same. It would charge when the tablet is on; it would not charge if the tablet is off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi this could possibly be a battery or charging port issue. I would check the port and see if there are any bent pins on the inside of the port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
phil philirvine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 51
