跳转到主内容
The Samsung Galaxy Ace is a low-end, slate-format Android device released by Samsung on February 2011. Identifiable by model numbers GT-S5830(i, B, C, L).
30 个问题 查看全部
The phone boots up, but the LCD wont turn on
The phone does turn on, i can hear it booting. But there is no image or backlight on the LCD. I don’t have another display to try and swap it.
I opened the phone and capacitors fell of the PCB, maybe they were corroded, so i soldered another ones from donor board . And 3 tiny ones on the side are missing
The lcd connector has electricity trough its pins so, the display has power.
Visually inspected the connectors and the components on the board are looking okay.
So any suggestions what i could do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
So there were two not so good looking components in the area around the LCD connector close to the backlight IC.
Darkened capacitor, i replaced it.
And one little darkened core-ferrite bead which i also replaced.
And problem solved! The LCD lit up!
I believe that the core-ferrite bed was bad, because its functions are to block noise for the backlight IC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Angewolf 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 39
