跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
134 个问题 查看全部
Samsung galaxy tab 4 Tablet reboots every 15 minutes?
After not using my tablet for about 6 weeks I struggled to get it to charge. After buying an original samsung charger its all sorted but not the tablet reboots every 15 minutes.
Following other suggestions I cleared the cache in asr mode, and have also done a full wipe in asr mode. Now it loads up connects to the wifi and then reboots every 15 minutes or so.
Any ideas? TIA ☺
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
13条评论:
I am assuming that what you mean by a “full wipe in asr mode” is that you have tried to do a factory/hard reset?
https://www.technipages.com/galaxy-tab-4...
完成的
Hi, Yes. Full factory reset by turning tablet off. Holding power, volume up and main button down until android symbol appears and then rebooting.
完成的
Sounds like a chip fault, changing the battery might help but it sounds like it’s on it’s way out.
完成的
Hi,
Does it do this with the charger connected and switched on?
完成的
Not tried that but will do that now and get back. Thanks!
完成的
显示更多的8条评论
添加一条评论
1个答案
Since i had many tabs that response badly when battery needs to be replaced i would try that first. Otherwise iT can be a heating problem. But my guess is changing the battery Will work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nichola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 141
