跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
327 个问题 查看全部
MacBook won't power on after display replecement
Hi,
I changed the display assembly from the macbook. After the replacement no image. The trackpad clicks when I power on the macbook but touch bar en green light shift does not work, no fans spinning. I can see an extern mouse is “working” when connected (red light from the mouse). 1 time the fans were running and another time I heard the charging bling (bling bling bling bling bling, … until i pressed power button). The GPU is getting hot (not extremely) when macbook is “powered on”
No visual damage to the logic board. What can be the problem and how do i fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Can you tell us why you replaced the display assembly. What lead up to it and where did you get the screen?
完成的
MacBook had broken screen. Still working but lcd was damaged. From my chinees supplieer .
完成的
Check for shortage on the LCD cable or ribbon damage. Use the old LCD or a new one to plug into mainboard and see if you get image displayed. Did the OS boot up prior to the screen change? Try external monitor. Possibility of shortage somewhere on mainboard due to new faulty LCD cable or PC boards.
完成的
添加一条评论
1个答案
最有帮助的答案
Disconnect the battery again and pull the ribbon cable going to the T-CON board from the logic board. Plug in an external display and see if the system starts up that way.
这个答案有帮助吗?
得分 2
2条评论:
Just tested with the external display. Still the same problem...
完成的
I don't get it! The external should light up. I think the new display was defective and zapped your system.
While you don't want to here it I think its time to visit Apple see what they say.
完成的
添加一条评论
添加你的答案
Mattis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 114
