跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
J5250 - C5250 - R5250 Removing After Water Damage?
Using a title that will get as many people from online to see it if they have the same problem and or an answer.
Customer spilled a cup of coffee behind the computer and it spilled inside through the air vents and onto the logic board BADLY! But 99% and some heat allowed a good ol’ cleaning. Anyways, it gets power, charges the battery, changes color at least but will not boot up, whatsoever. Tried no battery, only the battery and disconnecting everything, the usual steps before I ask for help.
On my PP3V42_G3H there is a thing on the board named J5250 with a Resistor ( I think) named R5250 and a capacitor next to it named C5250. Both are highly corroded, but I am unable to determine online what should be done with it. Or whether I should remove it or not.
Any suggestions?
I’ll include a picture of the schematics, maybe anybody smart can provide a good answer, should I remove the capacitor? Would this fix my problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@noah_smith “Both are highly corroded, but I am unable to determine online what should be done with it. Or whether I should remove it or not. Yes, if they are corroded they most likely have failed. Clean your board of all corrosion with some high grade isopropyl alcohol. then repalce the components as well as check the rest of the traces and components.
这个答案有帮助吗?
得分 4
3条评论:
Just making sure they weren't something not worth replacing. I've already cleaned it A TON, but I'll once over it again. Do you know what J5250 does?
完成的
J5250 is a connector
完成的
Ok, thank you!
完成的
添加一条评论
添加你的答案
Noah Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 152
