跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
425 个问题 查看全部
Car wont start after putting gas.
My car was on empty so I put gas at a cheap gas station and i only put 3 gal and all of a sudden 30 min later it starting to shake and put and I pumped the gas paddle and try to idle it and it shut off on me. So I figured it needed a cleaning of then injectors so I walk to the auto place and bought Sea Foam and pour the hole thing in there. So it start and ran until I got to my house and it shut right off. Soni filled the gas tank up and it turned on again but then 15 min later it shuts off again so I turn the key and still wont start, it turns but dont stay on. So this morning it turned on like normal so I left it on and then once it got to the car temp of the engine I turned it off, and not it wont at art again. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have a similar problem. I have a 2002 Honda Accord and I was on E, went to the gas station put $10 in the tank and it wouldn't turn on and I had to have it towed home. I replaced the fuel pump and it started for like 3 seconds and turned back off. It will crank but not turn on. Did you figure it out in your car yet?
完成的
添加一条评论
1个答案
Possible it is your fuel filter. I would change that out first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noel Ortiz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 215
