跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
120 个问题 查看全部
Can I replace a 2009 iMac 20" LCD Display with a 2007 2-" LCD?
I have a very dim and banded 20” LCD display on my Early 2009 iMac and I have a 2007 20 iMac with a good display just gathering dust. Can I swap out the displays?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
Hi Roger,
Based off of the Everymac pages for the 2007 and 2009 20” iMacs, I’d say it just might be feasible. If you’re willing to open the 2007, you could compare the connection cables as seen in Step 8 of the 2009 20” iMac teardown. If they look similar, it might be worth a shot.
Though before you open anything, take a peek at this page to see if you can find anything that might help in your case. If you know the EMCs then it’ll help you determine compatibility of screens like this one.
Hope this helps!
iMac Intel 20" EMC 2133 & 2210 Glass Panel图片
产品
$89.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roger Clay 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 50
