2008 iMac airport card upgrade
Hey all,
I have an early 2008 2.8GHz C2D iMac, and my wifi card is starting to give out on me. This would make sense, as it’s the original card that the system came with, and it is 10 years old!
I wanted to know if I could replace my old card with the Airport Extreme card found in the ‘09, ‘10, and ‘11 iMac models. I figure if I’m going to replace it, I might as well go with a slightly newer model that would fit the airport connector on my Mac.
Any advice would be appreciated.
3条评论
You can take a look at dosdude1’s Sierra, High Sierra, and Mojave patch tools that let you put those versions of macOS on unsupported Macs. If you are unsure if your Mac is compatible or not, just download the Patch Tool and when you open the patch tool, if your Mac is compatible there will be no warning but if your Mac is not compatible with the patch there will be a warning.
Sierra: http://dosdude1.com/sierrapatch.html
High Sierra: http://dosdude1.com/highsierra/
Mojave: http://dosdude1.com/mojave/
由 [deleted] 完成的
@ajcooke01 - This series RAM is very limited. The newer MacOS’s really need the bigger RAM footprint. I try not to push these type of solutions on anything less than i5 based system.
由 Dan 完成的
@danj My teacher had an old Core 2 Duo iMac from 2009 and I got Mojave on it using the patch too. It works just fine, even with 4 GB of RAM. Anything older then Core 2 Duo I would agree with you about not pushing too hard.
由 [deleted] 完成的
