跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
387 个问题 查看全部
Replacing the joystick circuit board in my Xbox One S controller
I've been trying to replace the left joystick on my Xbox One S controller and failing miserably at removing the broken one with the soldering iron. So instead I want to attempt at just replacing the circuit board itself, but before I do I have a few questions.
  1. I'm going to use a circuit board from one of the older controller models for the first gen Xbox One, the one without a 3.5mm headphone jack. Will it be compatible with the Xbox One S controller I'm repairing?
  2. If it works, will the 3.5mm headphone jack still work even though the circuit board is from an older controller model?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well there’s some good news, and some bad news.
The good news is that it looks as if you can put an original xbox controller board in a new controller body. Although I am not certain. Bad news is that the headphone jack will NOT work, as there is no physical connector to connect to on the older board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
knarrmatt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 551
