跳转到主内容
The Canon Selphy CP910 is a compact printer that connects to a camera, computer, and mobile device through a WiFi connection. It is the 34th generation of its kind in the Selphy printer series created by Canon.
16 个问题 查看全部
My Printer says ink is empty but I have a new one installed.
I have an Selphy CP760 and it continually says that I am out of ink even though I have replaced it 2 times.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I can not get my selphy 1300 to reg to my phone I had it for a while put it onto tablet but deleted it off tablet now won't register please help
完成的
添加一条评论
2个答案
最有帮助的答案
Since there is not any answers on this forum yet, I decided to answer it since I found the problem. The problem with this error is that the gear which runs the ink cartridge is missing? I took this device completely aprt and did not find any evidence of that gear anywhere. The motor that runs the cartridge is the smaller of the two.. I looked for a replacement gear for this motor but am unable to locate one. I did use this printer so I know it worked before. So that’s it issue solved sort of..
这个答案有帮助吗?
得分 1
1条评论:
How do you get to the gears? I took out 3 screws from bottom but can't get the four tiny ones out!
完成的
添加一条评论
Same here. Mine is a CP510, but I have seen the internals of the 7XX series and they are the same, and I have the same problem (it was working some time ago, now it’s not and when disassembling, I saw the missing gear). I am trying to look for a solution, but I think the best is to get another, or just forget about it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Terry 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 40
总计 3,863
