跳转到主内容
修复你的物品
维修的权力
商店
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
110 个问题 查看全部
battery do l use for 2006 chevy equinox
Replacing a battery in a 2006 chevey equinox
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
A similar battery in size and capacity as the current one.
Concerning size, it should fit the current housing, you probably have a size 75. And concerning capacity, the CCA (Cold Cranking Amps) and CA (Cranking Amps) are numbers of significance where the CCA lies probably around 650 and the CA around 800.
You’ll want higher numbers when you drive in a cold climate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Janet Caddy 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 10
总计 800
