How do you re-attach fallen-off keys on the keyboard?
If a Chromebook key is pulled off of a chromebook keyboard, how to you re-attach the key without the key immediately falling off again?
This guide should be of help for you. If the scissor mechanism is broken or if the little clips are broken on the bottom of the key are broken you will have to replace the key.
这个答案有帮助吗?
This article did not help me.
where can i replace a key
what store can i go to?
You can fix the scissor mechanism, just carefully take off another key and use that as a reference to putting it back together. If you snapped it in half or something, then yes it is unfixable and you need to get it replaced.
The link is about replacing the other keys, not the space bar. So for the OP's question, this answer is useless.
过去 24 小时: 17
过去 7 天: 80
过去 30 天: 365
总计 21,094
8条评论
thank you for your assentent
由 THOMAS REAVES 完成的
how to fix a keyboard on a chrome board os?
由 Kaleb Brown 完成的
Check this key clip to make sure it is not broken, Also check to make sure the peggs for the keyclip is not bend or broken. Then make sure that the bottom side of the key is also not borken. If all 3 of these are in good shape the key clip should snap on to the pegs, then the key should snap on to the key clip and all should be working fine.
由 Bryan Swedhin 完成的
what store can i go to fix this key?
由 Coach Eddie 完成的
I've repaired several of these. As long as the rubber cup is still on the keyboard, and it types that letter when you press the rubber cup. The key hinge clip and key its self are fairly simple to replace.
由 Bryan Swedhin 完成的
显示更多的3条评论
