跳转到主内容
Repair guides and support for a wide range of small engines.
76 个问题 查看全部
I have a Cub Cadet RZTS - It's 3 years old...engine is stalling out.
The engine idles fine, but when you goto move forward it dies out, but you an choke it and it will fire back up… it also does this when the pto is engaged. The previous season I replaced the air filter, fuel filter, oil/filter. This season i replaced the oil/filter.. the engine has less than 130 hours on it in the 3 years i have owned it. I dont know more than basic things. Anyone have any diagnostic tips? what to try? or what could be causing the issue. It had caught me at a bad time, being financially in a tight spot, Or I would take it to a dealer and just pay whatever. (Thanks in advance)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hey ford.tobey.
The carburetor might be varnished – usually caused by leaving fuel in the system for too long. The metering needle, jets, etc., may become clogged or glazed with the old fuel, which tends to become sticky (like varnish) and sneakily alters the prescribed air:fuel mixture. This is one way you can have a lean mix, as “cgulyash” indicated in his comments earlier. The fix for this is cleaning of the carburetor, or rebuilding it.
Whether or not you can do this on your own depends on your basic mechanical aptitude and your ability to follow the instructions to do the job. Some basic tools, spray carb cleaner, and an assortment of fine wires (compressed air helps, too), and all you need is the step by step instructions easily (normally) found on line. Good luck!!
这个答案有帮助吗?
得分 2
添加一条评论
Tobey,
Most carbureted engines need a little extra gas when the throttle opens and there is a load. That’s why car carbs all have accelerator pumps. This is aggravated by a lean mixture at idle. Lean mixtures are due to all kinds of things: dirty air filter, dirty fuel filter, carb out of adjustment, air getting sucked in because the carb is loose on it’s mounting or the gaskets are old, hard, torn, etc. If you are lucky, a half turn or so counterclockwise on the carb adjustment screw might do it. Make sure it’s not the idle adjustment screw, which will lower the idle. Actually turning up the idle a bit will also help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ford.tobey 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 59
