跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Samsung s6 edge suddenly charging slowly
My samsung s6 edge suddenly not having a fast cbarging capability and will take 5-6 hrs to be fully charged without use because if you use it the batt percentage goes down instead of going up
I change almost everything adaptor whatsoever
Nothing works
And heres the deal
I tried to put alcohol on my broken chord and put it inside my s6 edge to try to fix the issue or clean it with it then it works its not fast charge atleast i got 1 hr 30 something to full charge but heres the deal it always came ack after a bit of time and i need to repeat and repeat that again for me to be able to charge faster need help thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
something nes like dirt on the pins inside the jack, if you have a compressed air can use it to blow out any dirt that might be inside the jack. If that doesn't work you might have to mod a charging cable with a bit of felt or similar soft material, moisten with rubbing alcohol and insert & remove it repeatedly to remove any drt from the pins.
As a side note, keep your pockets clean as that is usually how dirt would enter the jack in the first place.
这个答案有帮助吗?
得分 0
2条评论:
Sometimes the charger port needs to be replaced to fix this problem, something a reputable repair shop can do via soldering.
完成的
Thank you i'll try it now
完成的
添加一条评论
添加你的答案
Fixie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,118
