跳转到主内容
The Series II Discovery debuted in autumn 1998 and in the US in 1999.
6 个问题 查看全部
Radiator is leaking not much but constantly
Radiator is leaking, still can manage with filling up
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Horst. If you’re certain your coolant leak is coming from your radiator, the only proper fix would be to replace it. There are some shops that repair radiators, but I would replace it. If you want to do the repair yourself here is a video of the removal process. Remember to keep your old radiator cap, as most new radiators don’t come with a new cap. When you’re finished be sure to refill and bleed the cooling system. I hope this helps. Good luck!
https://www.youtube.com/watch?v=TWCftAXY...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Horst 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 195
