跳转到主内容
修复你的物品
维修的权力
商店
3-D printer introduced by Aleph Objects in 2016.
1 个问题 查看全部
Extruder nozzle keeps jamming and stops midway thru a print from SD
My technology teacher has a Lulzbot Taz 6 3D printer that has some issues.
First of all, the filament sometimes jams in the extruder nozzle and therefore preventing the 3D printer to print anything. I have tried heating the nozzle to around 220 degrees celsius (almost overheating the filament) yet the nozzle still jams for some reason.
Second of all when printing a .gcode file from an SD card the printer stops mid print for no apparent reason, but when printing from a Mac mini it prints just fine. I have no idea why it does this.
Ideas?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
1个回答
已选择的解决方案
this happens when your nozzle is too close to the bed, the filament just builds up and stops print altogether, i would check bed leveling, Also check how old your filament is as over time they absorb moisture and become useless, last thing is clean your nozzle out if this doesn’t work, replace nozzle.
这个答案有帮助吗?
得分 1
评论:
@sosundi The filament is brand new and the bed is completely level so I will check out how close the extruder nozzle is to the bed. Thanks!
完成的
添加一条评论
添加你的答案
Aaron Cooke 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 343
