跳转到主内容
TI-84 Plus calculator support.
38 个问题 查看全部
It does not work..!
I tried to use shift+ sine but i think i accidentally pressed wrong button... Dont know why but after that when i press shift and sine a different screen appears. Then after a few minutes, it does not work... All the buttons (except ‘on' button) dont work....... Please help me. Thanks.
Update (09/19/2018)
Now i can't turn on the calculator....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
@hannah00000 Did you try replacing the batteries?
完成的
Yes. I tried.. But i think it made the situation worse......
完成的
@thelastmill Hey bud you have any idea whats wrong with this calculator?
完成的
添加一条评论
1个答案
最有帮助的答案
I assume by ‘shift’ you mean the ‘2nd’ button?
This issue quite perplexed me, I have no clue how you got to this state, but here’s how you could get your calculator back to normal.
The first thing I’d try is to:
  1. remove all the batteries, including the backup battery (there’s a guide on how to remove it here.)
  2. Hold the ‘on’ button for 10 seconds
  3. Put all the batteries back in (starting with the backup battery).
If that doesn’t work, try it again but, as Aaron suggested, with fresh batteries (including a fresh backup battery)
If that still doesn’t work, you’ve somehow broke something and it may not be a software issue. However, there are a one more thing you can try, an OS reinstall. Now that may sound scary, but it’s not quite as difficult as you’d expect. It’s hard to give you accurate steps in text so I’ll refer you to a video tutorial.
这个答案有帮助吗?
得分 2
2条评论:
@thelastmill Thank you!
完成的
No problem. :)
完成的
添加一条评论
添加你的答案
Hannah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 60
