跳转到主内容
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 个问题 查看全部
Note 5 screen will not turn on
i was tapping on my screen when all of a sudden it just went totally black. green lines appeared but then it went away. the screen did not turn on after. i was able to use sidesync to access my phone but it recently stopped working as the phone did not work any more. is there anything internally i can do to fix this? thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This sounds like your LCD has gone bad. The green lines you describe are what give it away. You can attempt to do a Glass/LCD replacement but keep in my the sub keys next to the home button are glued to the screen so be very careful.
这个答案有帮助吗?
得分 1
添加一条评论
Looks like you are due for a new Screen Assembly. I will provide a link below for the iFixit repair guide. The parts that you will need are in the Parts section of the repair guide (under the bottom right of the Introduction section). As @kcthreadsntech said the sub keys next to the home button are glued to the screen, so be aware and careful of that!
iFixit Repair Guide
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arsen Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 480
