跳转到主内容
The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
24 个问题 查看全部
Half of the screen is black
Screen has no *serious* physical damage (no cracks), but half of it is black. Touch screen works (including the black part of the screen).
What’s the problem and how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi @icecom ,
Has the tablet been dropped or gotten wet at all?
Connect an external monitor to the tablet's mini HDMI port to check if it shows a full display.
If it shows a full display then you have either got a video flex cable problem, a video flex cable connection problem or a LCD display panel problem.
If the external monitor's display also shows only a half screen display, then you have a GPU/motherboard problem in the tablet.
Here’s a link to the ifixit Nvidia Shield Tablet guide which may be of some help in opening the tablet so that the video flex cable/connector can be inspected if you have determined that it is not the GPU that is the problem.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Aleksey Timofeev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 38
总计 3,391
