跳转到主内容
A gaming laptop released by Asus with a CD/DVD drive.
20 个问题 查看全部
Asus ZX50VW (similar to gl552) won't turn on or show the charging led
I put my laptop in my backpack, it had a 50% charge and was running perfectly fine, next thing I know it won’t turn on, and when I plug it in the charging LED doesn’t turn on. I tried a different power brick, one with the same connector and voltage, but that didn’t work. I also tried disconnecting and reconnecting the internal cmos battery, but that still didn’t help. I also tested the stock powerbrick with a multimeter and it seemed fine, but the battery use a weird connector that I couldn’t find which pin was positive and which was negative so I couldn’t test the battery. Any ideas on what I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Take the battery out, then plug in the charger, and see if turns on being directly powered by the charger, if so it is the battery, if not, then it could still be the issue as the charger can’t power but I wouldn’t be sure. Other than that, you could replace the motherboard but that could be expensive. Have you fixed it yet? Been about a week.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Shelton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 647
