跳转到主内容
Replacing the motherboard's RAM bracket
hi, i have a motherboard that its rams brackets are not exist. how can i myself replace that brackets?
Update (09/12/2018)
i means they are brocken and missed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Do you mean the motherboard has markings for a ram slot on that area but there isn’t one put on there?
Those require soldering and nobody knows if that ram slot will work on that motherboard because it could be that the circuitry for that ram slot is not implemented.
这个答案有帮助吗?
得分 3
添加一条评论
If you really want to replace these missing brackets, I suggest you go on Ebay and purchase an identical motherboard; then install the better motherboard in your computer, and use the other one for spare parts.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
reza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 138
