跳转到主内容
Repair and support for the 2015 version of the Google-produced laptop line, the Chromebook Pixel. This newer version improves the processing power, battery life and add new features to the 2013 model.
14 个问题 查看全部
The screen is some blurry white.
I would like to know if someone can guess what happens with the screen. At the beginning I saw it at the left-down corner and now it happens at side and a little bit at the upper-left corner. Thanks!
Update (09/11/2018)
Thanks for all your answers. I just remember that before it got blurry white, I forgot it in the car under the sun and when opening, I saw some kind of glue coming out from the screen. is it possible that glue touched the screen? And I think that is cooling glue for the laptop.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Two possibilities.
  1. The screen is damaged. You will need a new screen if so. (Unlikely)
  2. The display cable is damaged. You will need to swap out the display cable if so. (More likely)
Maybe some people can comment repair guides down in the comments section of this answer so I can link them into this answer. ;-)
这个答案有帮助吗?
得分 1
添加一条评论
This model shipped with a defective LG monitor. You can find story after story on Reddit.
The screen starts to 'gray out' usually in one corner of the screen. Then a sticky goop starts coming out of the monitor. The computer is still usable during this period, but you lose more and more screen area until the device becomes unusable.
I was very excited to buy this Pixel. I like to buy high-end and then keep a device for a long time. Unfortunately, Google has a poor track record with its hardware. And the fact that they EOL chromebook devices prematurely is the last straw. I used to suggest chromebooks to non power users. But I don't anymore because of the EOL issue.
Since my Pixel is near death anyway, I'm going to attempt my first such repair on this thing and try installing Ubuntu. We'll see.
Sorry for your loss.
这个答案有帮助吗?
得分 1
1条评论:
My pi\el (the "eks" key has stopped working too) has just developed this screen problem. The sticky goop was the 1st problem, which keeps showing up in one corner. The gray out was ne\t. Now it intermittently gets a black, somewhat uneven border, with white bleaching out in the center. E\ternal monitor works luckily. Happy to find this posting e\plaining the problem. Let us know how your repair comes out. I may try it as well, as I really like this model. Another post here suggests CloudyReady to solve the EOL for the 2013 Pi\el. Might try that too.
完成的
添加一条评论
The Screen is Defective and you will need to order a new one or try to take it to the nearest Service Center they will fix it.
这个答案有帮助吗?
得分 0
添加一条评论
I have a similar problem, sadly. I thought it was caused by water went inside. It looks more like screen quality problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
buiminhnguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 382
