跳转到主内容
5-Inch Portable Vehicle GPS with Lifetime Maps and Traffic (Discontinued by Manufacturer).
Why does my device not turn on unless it's plugged in
It’s actually a Garmin nuvi 2995 but that isn’t listed.
It will only turn on when plugged into the car, my PC or a USB charger, then it works OK.
I’ve left it plugged into a USB charger for over an hour, but it still won’t turn on unless it’s plugged in.
Can anyone suggest a fix ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
are you sure that is the correct model number? I can't find anything about a 2995 model
完成的
I made 2 mistakes, it's a 2559 and, I thought charging it for an hour would be enough, it wasn't.
Charged it overnight, all ok now. Found out where to buy replacement batteries though.
Thanks for the help.
完成的
I have the same issue with a brand new Garmin ETREX 22x.
完成的
I have that problem with my Garmin nuvi55. Bought a new battery & still have the same problem
完成的
添加一条评论
2个答案
最有帮助的答案
Your battery unfortunately has probably gone bad google the model number and see if its repairable lucky in 2018 theres a video for everything. I don’t know if Ifixit will have parts for it try ebay if not look for good vendor.
这个答案有帮助吗?
得分 1
添加一条评论
My mistake, I thought charging it for an hour would be enough, it wasn't.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Frank Edgar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 1,967
