跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1645 个问题 查看全部
How can I fix water leaking inside the fridge?
My fridge is leaking water inside it. the leak comes from under the freezer , and when i push the “roof” under the freezer a huge amount of water leaks. here are some photos of my fridge and where the water is leaking
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @anaschahid ,
Have you tried turning off the water supply to the ice maker to see if the leak stops?
完成的
添加一条评论
1个答案
Sometime the fridge will have a outlet to get rid off excess water in the fridge itself possible this is clogged, look at the back of the inside of the fridge to locate
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anas Chahid 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 791
