跳转到主内容
Subaru Indiana Automotive commencing production in February 2004 for the North American markets for 2005 model year.
The car engine cranks very slow and doesn't start
After checking all sensors, changing spark plugs, CO2 sensor, crank pos sensor changing battery and so on, the engine keeps cranking slow and doesn’t start.
What is wrong with my car???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
tlccuroffice “the engine keeps cranking slow “ this would be caused by the starter. The speed of which it turns during start up is directly related to the rotations (and gears) of the starter.
这个答案有帮助吗?
得分 2
添加一条评论
If the sensors are replaced or the battery is removed, the ECU learning is reset. If the ECU is reset and there is no learning data, it will take some time to start cranking and start the engine. To learn the ECU, stop all electrical loads (air conditioners, etc.) and let them idle for 10 minutes. After that, if you drive and run 50-100km, learning will be completed to some extent. Subaru learns every 30km, so if you ride for a while, it will get better.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tlccuroffice 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 849
