跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
There’s a black “ink”spot in the bottom right corner of my screen?
My screen has no cracks on it, I’ve dropped it twice.
The first time it landed backside down and I noticed that a small black spot that sort of resembles ink appeared. I dropped it again today, it landed the same way, and the spot got bigger.
I can still control my screen directly on where the black spot is im just not sure what it is or how it could be repaired
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
4个答案
已选择的解决方案
If you could post a picture, we could say for certain but it sounds to me like the actual OLED has been damaged. If that’s the case, then you will need to replace the screen.
If you want a high quality screen replacement, then Apple is still your best bet. However if your housing is damaged, they may refuse to replace the screen, in which case an independent repair shop will be able to replace the screen. Just ask about the quality level of the replacement screen because there are some inexpensive (relatively speaking) aftermarket LCD’s and now aftermarket and premium level OLED.
这个答案有帮助吗?
得分 9
9条评论:
Hey does it spread all over after you dropped off ??
完成的
It's not spread ed it's just down at the last of the month
完成的
I just wanted to know what the plus was for at the end of the calendar
完成的
Nothing appears to be damaged it's just got a plus sign at the end of the calendar.
完成的
I don't believe anything is damaged if it is then the glass and back are a waste of mone
完成的
显示更多的4条评论
添加一条评论
Black splotches inside LCD display are caused by dropping the phone.
To get that fixed you would need to get the hole display replaced. Most expensive phone to get it replaced.
[关联产品丢失或禁用: IF377-003]
这个答案有帮助吗?
得分 6
4条评论:
Does the warranty cover this type of damage?
完成的
Does it grow with time on iphoneX?
完成的
It can get worse over time as it bleeds like ink in a display that expands. This would not be covered under normal warranty as it is considered physical damage.
完成的
Is there a way to arrest it?
完成的
添加一条评论
So I cracked my phone at the bottom right corner of my screen and it is showing vertical lines on that side of the phone can I get it fixed?
这个答案有帮助吗?
得分 0
1条评论:
You'll need to replace the display.
完成的
添加一条评论
I think this will be helpful for you
https://okadtech.com/how-to-fix-black-sp...
You can try the solution to solve this problem.
I was facing this issue in my iphone x tried this article solution it didn’t work.
Tried the same solution in a others phone it worked.
Conclusion - If the pixel is dead then you can’t repair it but if it’s stucked then it can repaired.
I dropped my iphone x so maybe the pixels are broken so i unable to solve this problem. I have to replace my screen.
It all differ.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Xandria 将永远感激不已
浏览统计数据:
过去 24 小时: 24
过去 7 天: 167
过去 30 天: 644
总计 207,095
