跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
496 个问题 查看全部
flood of water from bottom of machine
what would cause water to flood out of bottom of my machine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My washer is model 110.44422610
And I'm having the same problem.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @bear10 ,
Have you checked under the machine to see where the water is coming from?
It may be a cracked hose from the the water drain pump for example.
What is the full model number of the washer?
这个答案有帮助吗?
得分 1
添加一条评论
I have a Kenmore 600 series top loader. We had a problem with rodents in the house and they started to chew the drain hoses which caused the same problem. There are two hoses - one short one that goes from the bottom of the fill basin to the pump and the other goes from the pump to wherever your laundry water empties.
These hoses should always have a little water in them since they'll never fully drain.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jerry visconti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 534
