跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Boot loop caused by broken proximity thing?
Hello
I recently replaced my iPhone 6 screen.
During replacement, I broke my proximity meter thing.
The phone powered up fine, everything was working except for the proximity thing (when I made calls and held the phone up to my face, the screen didn’t turn off like it usually did).
The battery eventually died, and when I tried turning the phone back on, it got stuck in a boot loop. The apple logo seemed to flicker in brightness and sometimes I would get a red screen flash.
Other posts on here suggest disconnecting the cable and then trying to boot the phone up.
I did that, but the phone is still stuck in a boot loop with a red screen flashing sometimes. I also tried disconnecting everything but the home button and the screen itself. Still no luck.
Will installing a new proximity meter flex thing fix my phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Replace the proximity sensor cable. Then do a full restore via iTunes. It’s a hardware issue that caused a software glitch. Also try using the lcd shield from your old screen if you’re not already as aftermarket ones cause problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brink Laubscher 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 64
