Internal Blu-ray Reader or Burner that will fit in the 13" MBP?
I would like to install a Blu-ray BURNER in my 13" Macbook Pro to replace a dying superdrive. Is anyone aware of a device that will physically fit a 13" unibody MacBook Pro? I believe it needs to be a slot loading SATA device. I've already checked the usual aftermarket Mac suppliers with no luck.
EDIT: after doing some googling I have found the Panasonic/Matsushita UJ235 UJ235A, which appears to be just what I need. It's slot loading and claims to be "slimline SATA." Its dimensions are 12.7mm (H) x 128mm (W) x 129mm (D). Will this fit?
EDIT #2: Turns out that this will unfortunately not work. According to my further research, the MBPs require an ultra-slim 9.5mm thickness drive, whereas the Panasonic drive I mentioned is 12.7mm thick. So I'm back to my original question: are there any 9.5mm thick blu-ray burners out there? (I found a Panasonic UJ232A that is 9.5mm thick but it appears to be a tray-load drive...)
EDIT #3: At this point I'll even settle for a Blu-ray reader, so long as it's 9.5mm and slot load. Does such a beast even exist?
