跳转到主内容
Also known as a multitester, or a VOM (Volt-Ohm meter), a multimeter is an electronic measuring instrument used to measure voltage, current, and resistance. Includes handheld and tabletop testing devices.
29 个问题 查看全部
Non-contact voltage detector not working on Multi Meter
Hi,
I bought a Multimeter from JayCar Electronics today Digitech QM1529 DVM. It works fine but one thing doesn’t work, the non-contact voltage detector.
When I try to use it with the DVM it comes up with - 951 when I’m not even holding it up to something!
I hope there is a fix
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Robbie1155 are you following the manual for this meter?
完成的
添加一条评论
1个答案
已选择的解决方案
Sorry you have a bad unit you’ll need to return it for an exchange or buy another probe.
这个答案有帮助吗?
得分 1
评论:
Thanks I will exchange it :)
完成的
添加一条评论
添加你的答案
Robbie1155 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 370
