跳转到主内容
No backlight after liquid damage
Should I bother replacing my display assembly on my mac? The logic board works except no backlight on the display. I ordered a used logic board on eBay, but was wondering if I should order a replacement display as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi Paul,
It completely depends on why there is no backlight. There could be residual corrosion that needs to be addressed. It could be that the backlight on the display itself has failed. With liquid damage, I would suspec that the logic board is the issue. It is certainly repairable by a shop with the correct equipment and knowledge.
Cheers,
Joshua
这个答案有帮助吗?
得分 0
1条评论:
There is no visible damage anywhere on the board. I did a continuity check on the fuse labeled "P" according to some Google results. It appeared fine. I wasn't completely sure how to do a voltage check and didn't want to damage the board further. Also, the pins are so %#*@ small the probes on my multimeter would touch the adjacent pins and give me useless readings.
Also, after I had already seen a non-working backlight, I tinkered around with the LVDS connector cable...accidentally, and, successfully plugged it back in upside down and burnt a solder joint (I think that's what it's called). So I tried messing around with my soldering iron and flux and...probably ruined it more. The Mac still boots up...without backlight. I stopped touching it and ordered a new logic board lol.
I WAS going to try and replace the LVDS cable, but multiple experts have told me that I WILL break the glass. But, I'm not entirely sure yet if the display itself is the problem of the backlight.
完成的
添加一条评论
添加你的答案
Paul Ko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 477
