跳转到主内容
replacing the charging port with the port of the lenovo G505
i have an old Lenovo G505 that isn’t working
and my current laptop is the Lenovo z50 i was wondering if it’s possible to replace the charging port on my Z50 with the one on the G505
since they both use the same connector and both use the same charger
thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Although they both use the same connector and charger, the cable which connects the port to the mainboard may differ. I had a quick look at the pictures of both mainboards and it looks like the connector used is different. On the Z50, the connector is soldered flat to the board where as the G505 port is upright. I recommend finding a new charging port on e-bay or a part seller site which is made for your Z50. There is also the risk of the pin layout being different and you could damage the mainboard of your Z50.
这个答案有帮助吗?
得分 1
1条评论:
thank you good sir!
i will try replacing it with a charging port that is actually made for the z50
you saved me the hassle and the money i would've paid to take both laptops apart
thanks you again. :D
完成的
添加一条评论
添加你的答案
Gassan Abu Hirra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 480
