How can I get my tv to scan channels
I tried to hook up the cable line from the wall and then when I go to scan channels no channels pops up yet it says scanning complete scan what can I do
Be sure your setup on the scan is set correctly: If it is set to “Antenna” instead of “Cable”, the scan will not read correctly. (Some sets my have “On Air” instead of “Antenna” but you have to make the switch for the scan to work properly). Still not working? Try plugging in an antenna lead, or even a stripped-back the insulation piece of coax and scan under the “antenna” setting if in an urban area. If the tv picks up some signals, perhaps your cable line is dead?
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
This question was migrated from https://meta.ifixit.com/Answers.
由 iRobot 完成的
Sandra Erickson what make and model is your TV and you made sure that you have cable service?
由 oldturkey03 完成的
Hi,
Depending on make and model, check in the TV's settings area for a setting that allows you to select whether the TV is connected to an antenna (FTA) or a cable service.
由 jayeff 完成的
