跳转到主内容
Repair guides and support for a wide range of kitchenware.
71 个问题 查看全部
Rewiring a motor for 110 volts from 220 volt
Hi
I have a NutriBullet purchased in Dubai, designed to work on 220v system
Would like to convert to 110v operation in USA.
Rewiring would be easy if I knew which wires to reconnect.
Mel
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
I thought that the wiring of the phases are in series for the 220 volt and I just have to change it to a parrellel connection. A simple change if someone could verify that the motor will turn in the same direction as the original design.
Mel (Original POSER)
完成的
添加一条评论
1个答案
最有帮助的答案
@mrmel rewiring the motor is really not the way to go about this. You would actually have to tap into the wiring of the motor and not the wiring that comes out of the motor now. You would need an up transformer to get the voltage required for the motor. Or you can get an electrician to install a 220V outlet for your mixer. Anything like this is more expensive than getting a Nutribullet that is built for teh north american market. OIr find a broken one an scavenge the parts from it to convert yours.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Melvin Siedman 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 13
总计 290
